quick gas question???
thomasjones
Alright, quick question, does the gas i use for my 175 hp 1985 mariner matter. Should i use unleaded reguler, or use premium gas?? If it does, would it have an effect on the boat performance? Any advice is much appreciated.
rickdb1boat
Re: quick gas question???
Regular unleaded is recommended. You will see no advantage using premium and your wallet won't like it either..
Jigmaster
Invest in some Startron 2 strokes are more at risk for damage than 4 strokes if you are in an area of the country where most are by now we are now using the E-10 Ethanol fuels which my understanding is the gas drivers drop the gas into the tank at the Station they then add the up to 10% E-10 ethanol
guess what if is bad at math......and up to 50% have been tested in some Stations.
As of right now Startron 8oz. treats 128 U.S. gals is the only enzyme Defense against Fuel water ethanol Phase separation.> www.startron.com
outside of this 87-89 should be good if you have MTBE Fuel run it out before you add the new fuel Do not mix the two.
Good luck!
j_martin
The book I got with my 88 XR4 (V6 150 at least) said 87 or 88 would run, but 90 - 92 would be better.
Around here, the 92 octane (off road) gasoline has no ethanol in it. That's what I run.
Timed and tuned to the knat's $$$. It's fun to have the teenagers tell me to slow down.
John
adam89k
My advice would be save your money, you would never see a difference.
Unless you have a high perfomance rebuilt tuned up motor its just a waist of money.
Alot of people say high test is good for less wear and tear, but it's the oposite.
