Re: quick glassing question
To create a resin (polyester resin) rich layer........ It's intended to keep the sub-surface (plywood) or the 1708 from wicking the resin away from the other surface, which would starve that portion of the lamination of resin. And that could lead to delamination or poor adhesion between the plywood, the fiberglass &/or the resin. None of that would be good in a structural application/repair.
That's the 'reason' for using CSM before laying 1708 biaxial cloth. Depending on exactly what you're doing, stringers, tabbing, transom, deck, back-side of the deck, etc determines what to use & how to lay it up.
WOG's revised his graphic, to reflect that CSM is no longer REQUIRED (read
recommended in all instances) prior to using 1708, only in some instances depending on what is being glassed.
Terms like mat vs cloth aren't necessarily accurate enough to describe the products you should probably be using.
CSM is a fiberglass mat, but all mats aren't CSM. The CSM referred to in most (almost all) threads @iboats resto forum is 1.5oz mat.
1708 is biaxial cloth (17oz biax w/ 3/4oz CSM stitched to the back) but all cloths are not biaxial
Your
floor glassing question thread has a bunch of these details & WOG's graphic:
From his link:
"Fabricating Decks, Stringers, and Transoms"
If you are on an ultra tight low cost budget, you might want to take a day or 2 and read thru some info that's been provided & ask lots of questions. Lots of questions have already been hashed thru & posted in other threads. Reading some of them may help all this stuff make more sense, be easier to follow, and ultimately, when you start working on some portion of the resto, it won't be so frustrating & you won't 'waste' materials or time.
