quick question LH or RH Sterndrive? or is it just LH and RH motor? (hopefully)
menglor
So I bought a boat without an engine, and I found a dude with an engine.
Orginally , he promised me a LH rotation engine for my boat which is exactly what I needed.
But then sent me an email saying all he has is a RH rotation motor, and has agreed to give me the Engine, Drive and prop for the RH rotation setup.
Motor is a 4.3 mercruiser with a Alpha 1 drive.
So I have the following questions
1 -“ is there such a thing as a LH or RH rotation Sterndrive?
(I understand the prop is different, but what about the sterndrive?)
2 -“ Can I use a RH rotation engine with the Stern drive I have from the boat I bought without an engine?
3 -“ how hard is it to convert a RH rotation motor
4 - will a RH rotation fit in a LH rotation engine location? ( the Gimble is the old one) I read the starter is in a different location.
Bt Doctur
1 Have never heard of or seen a RH 4.3 motor, engine rotation is determined by looking at the flywheel CCW ,viewed from the pullys ,it would CW
Most outdrives are standard rotation (CW) , counter -rotating is done in the lower unit CCW
2 No
3 front and rear main seal are different, timing gears instead of timing chain
4 Yes, the motors are the same dimentions, but there never was a RH 4.3 motor
I Have never heard of or seen a RH 4.3 motor, engine rotation is determined by looking at the flywheel CCW ,viewed from the pullys ,it would CW
2 No
Ayuh,.... I agree on All points,.... Yer Seller don't know what he's talkin' 'bout,.....
menglor
As I understand he recycled a boat buying it cheap and parting it out, and from what I gather he is selling me the engine, and giving me the stern drive and prop from the RH side.
in my limited research, I have discovered a lot of conflicting stories, but from the last bit I read on sterndrive.com (i think)
is all mercruisers engines are LH drive, and the stern drives them selves are LH or RH.
at the very least, it sounds like I am going to get a LH motor no matter, and then have a spare outdrive if I want to go RH or part it out?
does that sound about right to you guys
btw, as always you guys are a god send in helping me getting going :)
achris
More fish than mountain goat
All STERN DRIVE engines are LH, but RH is an option for INBOARDS. When twin stern drives are installed, the way to get counter-rotating props is to install a counter-rotate gear housing (lower unit) on the port side.... The starboard (right hand) engine and drive (regardless of whether it's an inboard or a sterndrive) should be standard rotation....
