JSGOLD
Thread starter- Joined
- Sep 22, 2009
- 609
Late last year I had issues with steam coming out of the exhaust, so I replaced thermostat and head gasket. Took it out one last time and still had some steam coming out, but not sure if this is normal as I have not had the motor long and the water was getting colder...So I checked the water pump today figuring it was due to be replaced. It was old, old pc broken off, other edges were intact but worn and bent so that they were not rubbing against the housing...so yes time to replace. The question I have is whether the water tube can be removed without removing the power head. I know there is a grommet up there, but unsure if it can be replaced without a major operation....The pic I found online would appear to show that is not possible, but thought I should ask anyway. I have a manual for the lower unit but not the whole manual....Was trying to cover myself just in case. Hopefully the new pump kit along with previous repairs does the trick. Is it normal for SOME steam to come out the exhaust port?
