Re: quicksilver tach question
Does is still float to this value even with the key turned on? If it resets back to 0 when you turn the ignition on (i.e. the gauge is getting power), then don't worry about it. It should be reading correctly.
If it is floating to 1K RPM with the key turned on, then I would expect some sort of issue present.
