I just changed out the rack and pinion and I think I have a problem. The old came out quick and fairly easy; new one went OK. (Was told I would have pull the motor to install the cable through the tube. I didn't). I ran the cable first; centered the motor; then connected the motor arm. I installed the new steering pinion; then centered the steering wheel; then installed the rack. Much better! I turn the wheel to starboard; took 1 1/2 turns. Turned it to Port; got almost 3. Turning to starboard; its at the full turn.Got too dark to check the Port. Is this normal? Also; has anyone come up with a use for the bad cable? Junk?
