rapido 5.7 break in update
bolo78910
Re: rapido 5.7 break in update
amen to that , it was a long block with heads, as i said i spoke with the builder he said he has no problem swaping it.
danond
if u have3 nothing better to post please dont.
Hollering at someone because you don't like their opinion doesn't encourage anyone to help further.
bolo78910
who cares dude who wana help fine who dont wants to fine it not the end of the world, what u think iam going to do die hell no.
matter of fact yall can close this thread. who give that guy the right to say i was pointing fingers at the engine builder, just because his engine was great dosent meant mines has to be great all things are diffrent sometimes, i have a couple of guy on this forum who i have all the respect in the world for, they know who they are, not the one who just like to hop on and point fingers.
erikgreen
4 tell rapido the engine is a mess
5 i told him about the prob from day one hes if the engine has problem he will replace it.
From this, it sounds like you've already decided it was a bum engine, hence the finger pointing comment.
My advice holds... run a leak down test (you put air pressure in each cylinder in turn with an air hose and listen for where it comes out). It'll tell you if there's a crack or pressure leak somewhere, and it's easy to do. Air coming out the carb when a cylinder is at TDC, then you have a stuck intake valve. If air comes out the exhaust, stuck exhaust valve. If it comes out the dipstick, then you have bad rings or a cracked piston. Air coming out the sides of the head, cracked head or bad head gasket.
Alternatively, do a compression test. This uses a $30 kit from your local car shop, and it's also easy. You take out all the spark plugs, ground the coil, and put the compression gauge on each cylinder in turn. You turn the engine over about 4 times with the key, and read the pressure each cylinder delivers, and they should all be close in numbers and above 110 PSI. If you have a cylinder that reads 0, there's a problem there.
I suggest these to check whether the valves are leaking or what, and to localize whatever problem you are having.
Erik
wil7483
I think everyone here understands your frustration about the problems you are having with the engine but cursing and making foul comments toward the people you asked for help from isn't going to make things any better. I personally don't see the problem here. You have been given some excellent suggestions to help you diagnose your problem but haven't chosen to do any of them. Furthermore, Rapido has already told you that they will take the engine back and swap it out so what is the problem? You can't get any better than that. A no questions asked return policy!!!!! Lighten up and accept the help everyone is trying to give you or am I the next person you will decide to go off on?
bolo78910
erikgreen thanks , i am happy u didnt hold me on my harsh coment, i am just frustrated right now got laid of from work boat is not running good, my apology, what i will do is the compression test, if all cilinder holds at the abobe numbers i will just leave it at that , rapido said to just run it till it drop or broke but i dont like to drive my boat of car knowing that it is not running great.
thanks guys i will post my compression result.
mikeneal
I wish you luck and look forward to the test results, I hope you do not have to pull it, although I suppose the no questions asked return policy is great, I myself would be rather irritated with having to pull a "new" re-man motor out. I know stuff happens but still would really hurt my confidence in them as rebuilders.
As FYI, if you have Autozone auto parts in your town my local stores rent for free compression and leak-down testers (you just give deposit)
bolo78910
wil7483 dude you only join this forum in 2007 i already apologise to the only guy who i might get upset for stating i am pointing, that said and done. why you have to bring the darn subject back up.
you have no solution for my engine problem , listen up IF I POST A ENGINE PROB AND NO ONE FEEL TO ANSWER WHAT U THINK IAM GOING TO DO LOOSE SLEEP, DUDE GET A LIFE , ITS NOT THE END OF THE WORLD, COPY. now thanks for the good guys who know what it meant to install a engine only to have to haul the boat pull the ingine do it all over again, u feel me. u see guys like don s, bondo , just to name a few these are the guys who make this a great forum with many others . if they come at me like some of yll do that fine, because in the end they still give you great solutions, not just try busting ur chaps.
god bless iboat.
wil7483
You must be slow because I posted that BEFORE your so called apology. As I stated then you would find someone else to rant at and you did. Furthermore, what does when I joined this forum have to do with anything. Stop crying!!!!!!!
bolo78910
wil7438 what i would like to tel u they might ban me from this forum. who you think u calling slow boy.
look iam not even going to go there, i would rather deal with u in person face to face mano to mano, you dont know who u messing with. as for right now i will put you on ignore, if you wants to continue this come to brooklyn flatbush area we can have a nice talk, b**CH.
wil7483
How mature! Go and finish tearing your engine up. Maybe if you throw a big enough tantrum mommie and daddy will buy you another one. Definitely consider growing up.
FreeBeeTony
this thread should be locked...........has gotten way off track..........that's why noone else has responded...........i'm more interested in knowing the results of the compression test
bolo78910
tony and all the guys who try to help on this thanks , moderator please close this thread, when you get the chance. god bless
bolo78910
didnt know a fuel pump could knock
hi guys i was finish with this thread, but this forum has taught me a lot over the years, so i will share my find with you all , it might help someone else in the future, i was kinda busy so i did not get to do a compression leakdown ect, any way i perchase a scethscope, just to try and find where that knocking was coming from, this is a weird one, it was coming from the mechanical fuel pump yes the fuel pump, after doing a google search , and a iboats search i found out that yes these pump does knock, sometimes when some spring inside comes apart, but is still working, so maybe thats why i cant reach wot , i hope this may help someone else in the future.
god bless
bolo78910
oops foget to mention it only rattle at 1200 to 1400 rpm over that it kinda fade out, once rpm drop below 1200 the knock stop, engine oilpressure is over 40 at speed belo 20 after a long run, rev it up again the pressure goes back over 40 psi. from my manual that seems to me good. i hope
FreeBeeTony
Hope you found your problem bolo...........
When are you going to replace the pump?
bolo78910
sometime this week tony, i am kinda busy right now, i was going to send you a pm , but i thought someone might, comes up with a simula simptom and this might help. you know i cant wait to change the pump, without that tapping sound the engine sounds great oil presure is great also, will let you know soon. thanks
bolo78910
yea bubba let you feel like a echanic doctor lol
ILOVEBEER
I feel for you Bolo. Re-powers are definately a pain in the ***. I too have re-powered with a Rapido engine, and after all my hard work, I would be PISSED if I had to take it apart again.
That being said, I hope for your sake that your mechanical skills are better than your typing skills!!!!! Your posts are sure hard to read! ;)
Good luck bro, I hope it's a simple fix!
bolo78910
ha you got that right, my tiping skill sucks big time, anyway hang in there with me, lol
