Ratherb's 74' 21 Ft Starcraft Islander
Ratherbboatin
Current state of the project. I have only spent a few hours working on it, too many other things to do.
-Repaired aluminum above the top of the V on the lower window
-Drilled out an re-riveted the aluminum where the lower window posts mount to fix the large spacing on the window
Ratherbboatin
My wife told me to go buy another boat to use, so I came home with this one back in Early June.
Ratherbboatin
I have the top all painted and clear coated, Starting to put all the windows and top trim item back on. I can tape everything off to paint the hull.
Tnstratofam
Looking real good. :thumb:
I like your new shop too, and the new admiral approved boat. Sometimes people loose motivation on their projects when they add a new boat to the fleet. Good to see you're still working on the Islander.
Watermann
Oh man that shop is a beauty! Islander is looking good too :thumb:
Ratherbboatin
It has been challenging to find the time. I still have many things to finish on my shop.
GA_Boater
So you shunned the Islander for a trophy boat? LOL
Well, you came back to the old gal, the work is looking good, RBB. Nice looking shop, too!
Ratherbboatin
Upper Windshield now on! I am still trying to find some replacement rubber U channel for the lower window. It shrunk over 2 inches and is now way too short.
oldhaven
Man, I love the lines of these vintage Islanders. Looks like something Seal Team Six would be using. Great job on the fix and restore. I missed the beginning so I'll catch up in the next couple of days.
Ron
Ratherbboatin
If anyone noticed, I also replaced the trailer again. Last trailer was too small. This is a newer style Karavan Trailer with a longer wider frame.
Ratherbboatin
Lower Hull
The stripper works very well. I should pull the boat out and use the pressure washer to strip it, but I am applying and using a scrub brush to take off the old paint seems to work well.
Watermann
Looking good so far :thumb:
I would suggest converting the new chariot into a 4 bunk with maybe a keel roller in the back.
Ratherbboatin
The trailer is a split quad bunk version, not the best for this type of boat. It does fit better than all the other trailers I tried. I may change the quad bunks to 2 long 2 x 6 polymer covered down the road. It all comes down to cost, even switching the bunks over and using the existing mounts will be around $160 cdn. Our money is not worth anything right now.
I actually own a trailer business here in B.C. Canada www.jseequipment.com I am a dealer for Karavan and EZ Loader. Customers trade in used trailers when they buy new ones so who knows the trailer may get swapped again.
Watermann
Mission BC area, well we're almost neighbors, I'm in E WA across the border from Osoyoos BC.
Ratherbboatin
Off comes the old ugly worn out hull paint!
YUK! Stripping paint sucks, but it will sure look good after.
