FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
One of the local Glass shops donated me some good condition used U channel rubber for the lower window yesterday. Sooooo happy I found some. I will be installing the lower window over the weekend and continue with the paint stripping on the lower hull.
I spent some time over the weekend working on the lower window. Took it down to the bare aluminum and polished it up. New window rubber and some tint. I am happy with it!!
I expect I will only apply a few coats of varnish after I get it all sanded. I am about halfway done the sanding. I was not able to get the 3 small bow pieces out without taking the entire front panel off so they will have to stay how they are. Hopefully it won't bother me that I didn't do it......
WM what did you do for insulation? Did you cover it with anything after that? The factory had some sort of 1/8" thick soft foam insulation about 18" wide stapled on top.
Went through all the lower window screws and bolts, cleaned them all up. PITA. Very time consuming.
I dyed the bottom window rubber from white to grey as well. Test fitted the window and put the rivets back in.
I just received my aluminum edging and thought the item said it was 42 ft, turns out it was 4.2 ft. It was so hard to see the decimal in the ad. Guess I will go back and order a larger roll.
I still have the main cross-member to do. After I pulled off the old ugly vinyl wrap, it looks like the ends have some damage / rot. I looked at all local building places and no one carries 1 x 8 Mahogany. The closest replacement is oak, but it would be about $50 for the boat. I may see if I can repair with polyurethane glue. I also considered replacing with Cedar, but that wood is a lot softer and I am not sure it would make a good replacement.
I will be wrapping this main cross member with carpet, so looks does not matter all that much. I might consider cutting it out of plywood, but I only have regular around and no marine stuff.
Actually after I went over it with the sander, added some poly glue, clamps it seems good. The glue dried and has been sanded once. I just applied more glue. Should be stronger than when it was new. I will post a pic when I am finished. It looked worse than it was.
