rebuild or part out?
beach
Have a mercury 1986 75 hp, motor frozen lower unit trash. Is it worth rubuilding or should I part it out? Everything else was working has tilt and trim.
Greg New Zealand
Re: rebuild or part out?
Your motor is 18 years old and sounds like it has a lot of problems $$$$ :( <br />You need to do a rough costing to repair and add another 10-15% to cover other things that you may have to fix. Unless you can find a source of good value parts you may find the $sum is a long way towards an upgrade. Good luck :)
KCLOST
beach, <br /><br />If you really like the motor, hang onto it.. Look around for a used engine of roughly the same year. Maybe you'll find a good used one cheap and will have your old one around to use as parts...<br /><br />Just a thought...<br />EBAY!
Clams Canino
I know a guy that can prolly fix *that* powerhead for about 500 clams including parts but not shipping.<br /><br />-W
MercMark
I have a 1974 850 with a bad powerhead, lower unit should be good, had some work done to it two years ago to fix it up. <br /><br />But... I imagine the difference in year means that the lower unit won't fit.
