+1
You could replace the Speedometer and Pitot tube only to find it still does not work because the hose pinched in the middle. Throwing money at a problem is just throwing money away.
If you feel that $20 is not worth the effort to find the problem.
Do this, take $20 out of your wallet right now.
Now burn that $20 just for fun. If you can't bring your self to do that, go find the problem in the boat first.
The Test...
Remove the hose from the pitot tube and blow into the end of it.
The far end of the hose is blocked by the speedometer so no air will actually flow, only pressure.
If you can get air to flow into the hose, it is cut somewhere
A health set of young lungs should be able to blow ~10 mph.
If you get Zero on the gauge, Remove the hose from the back of the gauge. It just pulls off, no connectors.
Blow into the Hose from the gauge end. You should be able to blow air out the open end by the pitot tube.
If not, the tube is Pinched or plugged with mud or insects.
If air comes out the other end, reattach it to the pitot tube and blow again.
If the tube is now blocked, the pitot tube is plugged up with mud or bugs.
Should have asked this first... Is the Pitot tube Mounted Correctly?
