Just started pouring wet snow. yeaa
i refuse to live anywhere i have to shovel water, thats what props is for![]()
So went out and installed a Moeller # 35722-10 electric fuel tank sender.[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/thumbs.ebaystatic.com\/d\/l500\/pict\/191800927020_1.jpg"**[/IMG2]
It has of course a connection for sender to gauge and ground. My question is my tank does not have a tab on it for
bond/ground like the newer tanks I see. So do I need to add a tab and wire for bond or am I grounding the tank also which needs to be ran to fuel fill to stop static issues.
Can I piggyback off of the sender?
This is not my tank but you can see the separate tab I am referring to. It is separate from sending unit.
Thanks.
DC electric is challenge for me at the moment. I've been reading my nuggs off about it.
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/www.northerntool.com\/images\/product\/700x700\/349\/3490201_700x700.jpg"**[/IMG2]
Yeah but ya just have find the right one ...![]()
How many props Mick? Total?
I'd answer your wiring ? Kev if I knew the answer......the only thing i screw up more than DC wiring is carbs....
