Remove Motor Help
joeturse
I have a 2001 Johnson Oceanpro 150 that I need to remove from the boat.I have an engine hoist to do the job.What I need to know is where to connect to pull the engine.
Thanks
Joe
countvlad
Re: Remove Motor Help
Thanks
Joe
use the flywheel to pull the motor there are 3 holes on top of it... ive also used the flywheel and the holes on the heads to remove the motor before...
Eshaw150
When i changed mine i raped a chain around the mid section, BEtween the powerhead and the shivel point on the mid section. Avoided useing polts on the flywheel and chancing the bolts ripping out and tearing up the threeds
Eshaw150
tmcalavy
Some powerheads are tapped for a lifting ring, usually aft of the flywheel.
Lion hunter
You need a lifting ring that attaches to the flywheel. Might be able to get one or rent one from an OMC dealer.
reeldutch
on this 60* engine there are 2 lifting wholes casted in the block
i believe 1 is close to the starter and the other one is oposite of it.
you cannot atach a lifting ring on this flywheel
you would have to take the cover of and the optical timing wheel and blah blah blah
cougar1985
took my 90 off by hand,me and a buddy ,a little awckward but not so bad.mind you were both big guys and it was a ,i wonder if we can do it type of thing.on the 90 there is i lifting ring all ready cast there.doctor says i will never be able to walk straight again,lol.
Chris1956
Honorary Supreme Mariner
As Dutch said, there are two cast in places to attach chains. That motor weighs 400+ pounds, so make sure you have strong enough stuff
joeturse
Have one of these-----:)Ordered a shop Manual two weeks ago.Must be coming by snail mail.
