WallyMaster
Thread starter- Joined
- Oct 9, 2007
- 17
I need to remove the bearing carrier from my Merc 9.9 in order to replace the seals. The manual says that a special tool is required to remove the carrier, but if the tool is not available it states that you can use the thrust hub as a removal tool by placing it on the prop backwards, with the hex end of the thrust hub now exposed, and the hex end of the hub will fit a conventional box wrench, thereby becoming the removal tool. But I have done this -- placed the hub on the prop shaft backwards (as it says to do) and the hex end is exposed... but now what? If you put a box wrench on this hex end and turn it, it just turns the prop shaft. It is not clear to me how the reversed thrust hub is used to remove the bearing carrier. What am I missing?
