Sinkingslow
Thread starter- Joined
- Jun 27, 2009
- 32
I have a 1974 115 horse Mercury 6cylinder outboard with a two piston tilt trim. The transom is soft. I am trying to remove the motor and hydraulic tilt trim so I can work on the transom. I have little experience but wanted to do this as challenge, but I do not want to break things on the removal. I am trying to figure out where the hydraulic tilt trim stops and the motor begins. I have been removing bolts and have undone the pistons for tilt trim. I have a small cable that is leading to the lower unit. Before I start to remove the 3/4 bolts on the lower unit where the cable is, I thought I might get some advice on what to not do. Any thoughts?
