Ironhorse2022
Thread starter- Joined
- Oct 14, 2022
- 47
Hello, I recently bought this motor and didn’t notice the small, but forceful leak at the bottom of the exhaust cover. Disassembly revealed 3 stripped bolt holes, the exhaust baffle cracked into 3 pieces and a large dent in the block-side gasket surface (wear the leak was happening). I’ve fixed the stripped holes and gasket surface damage but am struggling with the baffle. I tried using an aluminum brazing rod (w propane) last night with no luck other than to deform one of the pieces slightly. The baffle is discontinued and I haven’t found a used one yet. I wondered if there any other suggestions ? If I could find a good tig welder I guess I could be an optionI but I’m concerned about flatness and ability to seal when reinstalled. Thanks for any help.
