Repair or replace the exhaust baffle for ‘84 suzuki DT30
Ironhorse2022
Hello, I recently bought this motor and didn’t notice the small, but forceful leak at the bottom of the exhaust cover. Disassembly revealed 3 stripped bolt holes, the exhaust baffle cracked into 3 pieces and a large dent in the block-side gasket surface (wear the leak was happening). I’ve fixed the stripped holes and gasket surface damage but am struggling with the baffle. I tried using an aluminum brazing rod (w propane) last night with no luck other than to deform one of the pieces slightly. The baffle is discontinued and I haven’t found a used one yet. I wondered if there any other suggestions ? If I could find a good tig welder I guess I could be an optionI but I’m concerned about flatness and ability to seal when reinstalled. Thanks for any help.
Buy a used one off eBay or see a real welder
Ironhorse2022
Have been watching eBay for a month now. Missed one by a day but no others listed. Will start looking for a good welder but without a recommendation in this area, it’s hard to separate the good from bad before they have a go at your part. You’ve mentioned radiator shops before but the ones around here just replace with new. I’ll ask around at a few shops.
I think I would make a new part.----Stainless plate with some guides welded on for exhaust flow.
Ironhorse2022
Wish I had those kind of fab tools / skills. Yes, 20, 25, 30hp all use the same plate. Have been searching under all three. Good question on the years. So far, 83-85 seem to be the same.
