Lou C
- Joined
- Nov 10, 2002
- 14,279
Re: Replace drum brakes with disc breaks?
I think you'll be far better off replacing all of the old stuff, and being in a salt water area, you want to use the best stuff you can. Having said that, I re-habbed my old Load Rite about 7 years ago, new axle, springs, and added brakes. At the time, disc systems were still somewhat troublesome so I went with drums. My use is similar to the original posters, the boat stays on a salt water mooring and the trailer gets dunked only about 4 times per year. With that, the drums have not been a big problem. I replaced the original backing plate assemblies after 5 seasons. I found that in order to make drums last, you need to remove the rubber dust seal (it's not water proof) and put some syn caliper grease on the piston and in the inside of the rubber seal. Then take some high temp RTV and use that to help seal around the seal where it goes over the edge of the wheel cylinder and in the hole that the pushrod tube goes into in the seal. Finally, use some OMC/Bombardier triple guard grease (water proof grease for salt water) on the threads of the adjuster, these often freeze up. If you do these things you can keep water out of the wheel cylinder and stop the piston from seizing, that's what causes most of the trouble with drum brakes. Still discs will be better, if I was putting on a new system now, I'd use discs. The only advantages of drums is that for light weight trailers, they may work better because they are self energizing, they provide braking action at lower brake system pressures than disc brakes can. Thats why disc brakes on cars always have a power booster, but years ago on small cars it was common to have un-assisted drum brakes. Also they run cooler on a surge system because the return springs prevent the shoes from constantly rubbing the drum, unlike disc brakes.
see
http://www.championtrailers.com/techsup.html#techretro
http://www.championtrailers.com/DrumVsDiscBrakeArtcl.htm
http://www.championtrailers.com/DISC_BRAKE_INSTALLATION_ARTICLE.HTM
see
