Replace VRO pump 70 hp Johnson
CED8ED
I have a 86 Johnson 70 hp with a leaking VRO pump. It is leaking fuel badly. I want to replace the VRO with a premix pump. Can anyone tell me what pump will work with this motor? The cheaper the better. Thanks in advance.
tashasdaddy
Re: Replace VRO pump 70 hp Johnson
Vro Replacement Fuel Pump Kit "no Oil"
(for Using Oil/gas Pre-mix In Fuel Tank)
#5007422 it is in the $300 range.
$100 range
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
CED8ED
Thanks tashasdaddy. Do you know of an aftermarket one?
noelm
Is there a valid reason why you do not retain the VRO system?
Boss Hawg
Don't know bout him but i've got peace of mine knowing my '87 70hp is getting the exact right amount of oil/gas mixture by leaving mine unhooked & pre mixing :rolleyes:
Sorry if i went left feild on anothers thread :redface:
CED8ED
Yep. The pump has started to leak fuel and I wanted to replace it anyway. I have already lost one motor because of a VRO failure.
