replace vro
ricko
I cant figure out where to connect the 4th wire on the new vro pump.(purple one) I dont have a purple wire on the terminal board and i am not confidant about the only choice i have found. should I cut into the 1 purple wire i did find thats going up to the flywheel area of the engine.
rickdb1boat
Re: replace vro
Hey Rick<br /><br />Head up to the red search button above and enter "4 wire vro". You will find out all you need to know...
ricko
Re: replace vro
Rick, I went to search and find nothing!!no results what gives???
rickdb1boat
Re: replace vro
I get 135 results. 4 wire VRO in the Johnson/Evinrude section....
ricko
Re: replace vro
Rick<br /> This is what i am doing and get no 135 results<br />1 At the top of page i hit SEARCH<br />2 I ENTER, 4 wire VRO<br />3 HIT. match all<br />4 hIT, Johnson& Evenrude outboard trouble and repair<br />5 Hit, Enteir message<br />6 Hit, Any date.<br />7 Enter my membership number.<br />8 Then at bottom I hit SEARCH.<br /><br />Ricko
seahorse5
Re: replace vro
What part number pump kit did you get? The correct pump kit includes the purple 4th wire and a 4 wire connector and instructions.
