gazza2007au
Thread starter- Joined
- Mar 9, 2007
- 429
i had water leaking into my lower unit through the drive shaft bearing assy the outer O'ring was the cause im just wondering if i can idle the motor in a bucket of water for a period of time to see if the seal is still leaking or will i need to actually run the motor up to certain speeds to build up pressure inside the lower unit?
cheers
cheers
