Be sure you haven't desturbed plug wire or other wires that may be exposed.
Did you have the flywheel off?Did you torque the nut correctly?
Flywheel torque:: Aluminum,400 -450 in lbs., iron with steel insert 375-400,
w/o insert 180-200.I would think there is a spot where wire would normally
be clamped or secured.Wire must pass through the stator plate somewhere thats where I would look to secure.
