Re: Replacing Electrical Switches
Switches break the hot leg...you should have one in that's hot from a breaker and one out to the load...and a green ground...The neutral has nothing to do with the switch(typically)...That picture is wrong for several reasons..The fan is on the left, the light on the right, what is in the middle? It looks powered all the time...
I don't agree with what hrdwrkingacguy has written, (I think he has just misunderstood the drawing), but I know he could do this job in 15 mins or less.
We have all gotten off-topic I think.
The answer to OP's original question, IMO, should be "there are so many whites attached together because this schematic has a line-in entering a switch box. Those white wires are neutral conductors and need to be connected.
It is far more common (and I suspect what OP is familiar with) for the line-in to enter the fixture box and so there is only one or more switching conductors running to the switch box..... black and white conductors.....but the white(s) is/are NOT a neutral".
