buckeyemanny
Thread starter- Joined
- Dec 30, 2023
- 8
How do you change the bendix on a 1990 Evenrude 25 hp
I guess, I should also ask. How to remove the starrterFind the hex on the bendix.------Put wrench on it and the nut.-----Remove bendix.
Unbolt the bracket....the starter goes with the bracket. You also have to remove the two small screws and small brackets holding the throttle rod assembly.I guess, I should also ask. How to remove the starrter
Thank you.Unbolt the bracket....the starter goes with the bracket. You also have to remove the two small screws and small brackets holding the throttle rod assembly.
Somewhat obvious as you start the removal process.
When I switch the key to the start position. The starter spins but the gear doesn't engage. I have 12.4 volts at the starter. I bought the boat a month ago and it worked when I bought it.How do you know that bendix is bad?----Any trouble shooting done ??
Bracket is not hard. Nut/bolt in front next to the carb. Two more plus upper throttle mount. Starter wire, pull assembly forward.The battery is good. The starter is good. All the conectios are good. The bedix is hanging up. I tapped on the shaft (lightly) and the bendix and it started working.
I want to take it apart, clean it and replace anything that needs replaces. I want to have a reliable motor.
Thanks for all the comments and assistance. That bracket looks like if might be a bear!
to true , till there is a short somewhere as i expect is the case with the OPs .Starters are fairly simple to check out.----Is this the factory original starter or something else ( cheaper ) ??
starter will work fine till its under load ,
on that note , if you are game enough prod at the under side of the drive with a screwdriver while its trying to engage , see if it catches and cranks the motor .
