brian3127
Thread starter- Joined
- Jun 10, 2007
- 525
i am replacing the floor on my boat mainly because the foam under it is water soaked. so im going to pull all of the foam out and fix the leak. my question is should i replace the foam or not. and if i should what sould i use. the foam that you get in a spray can or is there something else i should use
thanks
thanks
