Re: Restoring my MFG
Hi Guys,
When I started this project, my goal was to get my boat as close to original condition as I could. Sure, I've made some concessions.
The gauge cluster is one example. However not original, I tried to make it "period correct"
One item I had to tackle sooner or later, was the Helm and steering setup.
The steering had been up-graded by the previous owner to a Teleflex Safe-T rotary set up.
I always thought my boat might have had a drum/cable and pulley system. So, I crawled up under the dash, gunnels and splash-well and found no evidence of such a system. Hummm...
After much research and conversations with experts, I concluded it once had an early teleflex system. Pre (Safe-T) model. This was all well and good, but going back to this system wasn't going to be an option.
So, back to the drawing board.
I took a second look at the system I had, and the newer version, the Safe-T II QC. All I needed was a new cable for mine, and it was still available.
Now all I had to do, was to figure out how to use the helm I had and fit an original wheel and bezel to it. Thankfully the original wheel was a 3/4" diameter shaft and would go on nicely. The bezel was another issue. The one I had, was just not going to do! It was way to large, Black plastic with a funky textured finish on it. It's the one on the upper left.
The white one is for the early model and the chrome one, is for the drum/cable set up. As luck would have it, neither one of my choices would fit over the newer mounting bracket.
Now I realize, it's only a bezel here... but I wanted something that would look right. If I didn't have to look at all the time, then maybe I could let it go. After much haggling with myself, I decided to fabricate something that would work. And if I were going to invest the time and energy to make a bracket I was going to use the chrome bezel ( I like shinny things!) Yes, it's not original, but close enough!
[/IMG]
