justinteoc
Thread starter- Joined
- Jul 24, 2013
- 51
on the 3.0 GSMLKD between the exhaust manifold and the elbow that attaches to the exhaust there is a plate that goes between the 2 that only has a hole in one side ( its square) i believe in that elbow there is so much buildup that water can not flow through that one channel fast enough to keep the engine cool. Would it be ok if i left that restrictor plate out? Will this damage anything or cause a problem? Also im not sure the terms for the exhaust manifold and the elbow could someone explain to me what there called? What is actually called the riser?
