Hi there,
I have a 1990 Johnson 120 V4 that's been running rough at an idle since I bought it this spring. I pulled the carbs right off and even though they looked spotless I cleaned them pretty thoroughly and re-installed. Given the shape of them, I wasn't surprised that it made no difference. Finally broke down and decided to pull them again and throw in new OEM kits. As I was cleaning them again, I was blowing air and through the pickup tubes that run from the bowl up to the idle & mid range jets. Air was coming through, but I decided to hold a light to one end and look through. The mid-range was completely clear the whole way, the same size as the brass tube. The low range seemed to be restricted a bit. I tried air and then come carb cleaner with no change. I ended up trying to clear it with a tip cleaner/reamer for my welder. What I discovered is that the hole is restricted to a fair amount smaller than the #41 jet. This would certainly make some sense out of the rough idle. I pulled another carb and found the exact same situation, clear mid and restricted low.
Thinking that the tube should be clear that whole way like the mid-range, I figured I'd ream it out. It does NOT clean easily and I might have to buy a drill small enough to try to drill it out. It's just bending the reamer.
Before I went and reamed this hole larger, I was hoping someone would confirm that this makes sense. I'm assuming that the fuel flows from the bowl through these tubes to the jets and not the other way around.
They should be completely clear, right???!
Thanks again,
Evan
Thanks again,
Evan
