wendellbee
- Joined
- Sep 3, 2014
- 40
So i finally (after over a year) got my parts from my mechanic and put my port engine back together. What I thought was a broke timing chin turned out to be 2 frozen valve and a cam pin sheared off. Engine starts up and runs good. problem is i'm not getting water thru the risers. while manifolds were off I did run water thru them to verify they flowed.i didn't run water thru the risers so i believe they are clogged. has anyone used the Sierra risers or recommend a decent riser? I know i can't get any OMC manifolds or risers for this motor.
