Rivets Everywhere....
croag
Hi There - Is there a standard type & Size of rivet that is used on aluminum boats? I'm dealing with a 12' that i need to re-rivet in spots but i'm not sure of the rivet size i need to buy. Are these things pretty standard?
109jb
Re: Rivets Everywhere....
They are usually in 1/16" increments on diameter. Like 1/8", 3/16", 1/4" etc. As for length, they need to be 1-1/2 times the rivet diameter longer then the materials being riveted. For example, the materials being riveted together total 1/4" thick when stacked together and the rivet is 1/8" diameter. Then the rivet length need to be 1/4" + (1.5*1/8") = 1/4" + 3/16" = 7/16". Then after bucking thhe rivet the bucked side should have a shop formed head that is 1/2 the rivet diameter tall and 1.5 the rivet diameter in diameter. So for that 1/8" rivet the shop head should be 1/16" tall and 3/16" diameter. To get the correct length before installation, you can get a linger length rivet and cut it off using a rivet cutter, or in a pinch, I have ground or sanded them to length.
109jb
Oh yeah, If the hole is all buggered up then go to the next larger diameter rivet and drill the hole so that you have a clean hole.
