Rolled Roofing
SpinnerBait_Nut
When laying rolled roofing down, do you use the black tar at each overlap?
Also, how big of an overlap do you create?
newbie4life
Re: Rolled Roofing
Yes.
The asphalt roof coat is used. It usually comes in a 5 gallon bucket, and is extrememly sloppy. Becareful on the edges of your roof -- If your not, the roof edge will look like crap.
1/2 lap roofing requires a half-lap of coverage. It's a heavy felt paper on the top half, and while someguys only mud the edges where the next lap will fall..... I'm convinced I'm gonna slop and mop the whole top 1/2. The tar is relatively inexpensive compared to a leak.
Re: Rolled Roofing
Ayuh,.......
Are you using 1/2 lap, or single coverage,..??..??
I put a layer of Single Coverage on the Riverhouse to band-aid it thru til the Big Lift is over, when it'll finally get a Steel Roof......
We slathered about a 6" strip along the lower edge of each sheet......
And the Overlap worked out to about the same 6" in most places,....
Some were slightly more,+ some slightly less....
That sounds alittle Extreme to me,.......
newbie4life
Re: Rolled Roofing
Ayuh,.......
I'll take extreme over a leak ANY day. I've never had a leak on a flat roof yet, knock on wood. Water is such a sneaky beast.
JB
Re: Rolled Roofing
I used rolled roofing on a stable once.
Used the tar at every overlap of about 6". Still solid when I moved.
12
SpinnerBait_Nut
Re: Rolled Roofing
Yea went with the 6" lap and black mammy at the laps.
Thanks all.
