Rotten 1982 Beachcraft
Beachcraft170E
So at this point in our recap, it's late November, and I started the build in late June, so right at 5 months worth of pretty obsessive work, when I'm not at regular work. In hindsight, it cracks me up how close I thought I was at this point. I figured a wash, cut and rub the gelcoat, pop the interior in and we're on the water baby. 🤣 Oh my young, naive self. Now I realize that about every 3 weeks I say, "about 2 more weeks." Anyway, I figured better start on the gelcoat. It had some keel rub, as I mentioned earlier, some big gouges, lots of rashes and dings, and oxidation. There were also holes to repair and the glove box area. I spent a fair amount of time on it, and though it's far from perfect it has really come out nicely.
Beachcraft170E
Munching popcorn with anticipation as the story unfolds…..
Thank you for checking it out. I know most of these build documentations are usually more engaging if its real time and question and answer. I do hope anyone who happens along and sees how I or the factory did something can be helped in figuring out their own solution.
buxmj
Great work! Thanks for taking the time to go back and post your journey. I have had those same thoughts about how long things should take and how long each step actually takes, very frustrating initially but in the end the boat looks better and is safer than when it was built, yours definitely falls in this category.
Beachcraft170E
The motor got a clean up while it was out of the boat, new gaskets, paint etc. The outdrive got a new impeller, seals, fluid change, pressure test, etc. There was also some prop damage, so I had that repaired locally. It's a stainless prop, so worth it. And it was only like $100. We got take out Chinese food this weekend and it was like $73. So if my wife asks how much the prop repair cost, I'll just tell her "A Peking dinner for 4 with extra egg rolls." 🤣🤣It should make about as much sense to her as the rest of the stuff I mutter under my breath to myself.
Beachcraft170E
I wanted to get the flooring in, so that the epoxy resin wouldn't be exposed to too much sunlight. I went with a pebble grain marine vinyl glued down with contact adhesive. Contact adhesive gives me anxiety. If I were to do it over again, and I may in the future, I would probably do a textured gelcoat. I dread the day I decide to remove the old contact adhesive. I also got the sides of the hull carpeted, and the seat mounts sorted out.
Beachcraft170E
After the flooring, you know you have to do some test fittings!! And she got a name!! The Admiral's nickname
