Re: Rotten Transom. HELP
I finally took out all the wood from the transom today.
I couldn't work on the boat for a while because of work.
a couple of weird issues:
1- I can swear, some spots in the wood were not even touching the transom fiberglass/hull. check out the pics.
2- the bottom of the transom did not have anything to glue it down to the bottom of the hall or tap it. I actually found foam instead of glue :s.
Oh, and in one of my posts, I said I couldn't find any foam. Well, I was wrong, There was plenty. The reason why I couldn't see any is because under my deck, I found a second layer of wood that went only from the main stringer to the second stringer right next to it. It was wood, chopped strand mat, About 1/2 inch gap that had what I think was glue but in lines of about a finger wide, then the deck that had 1708 from both sides.
Have you guys seen anything like that?
from the threads I have read and seen, This is the first I've seen like this.
Waldo
