RPM Tachometer not working
Mike Cherry
I have a 2004 150hp optimax on a 2004 1903 CC Trophy and my RMP gage has stopped working. I have checked my wiring in the dash of the Trophy and now I need to check the Optimax. Where do I start checking on the outboard? Any help would be nice . Many thanks
Faztbullet
Re: RPM Tachometer not working
Have you got the standard gauge or the multi function? Does the needle drop when switch on? If you are sure you have +/- at gauge check the harness connector that feeds instruments,connecter at engine and finally the connections on EMM.
Mike Cherry
Frist ... thanks for the help !
I have a multifunction gauge and the needle does not move when swithed on. Do you know where the connector is located on the engine ?
Faztbullet
If you have a binnacle mount ,the instrument harness will be under dash near the key switch. Just follow wires from gauge back toward switch and you should find a 5 pin male/female connector.
hl
I do not much about these mulifunction gages. Would a bad rectifier cause the (RPM) tach problem?
Bamaman1
The multifunction tool measures ohms, resistance, etc. It also measures volts and other things. It's used universally in car and boat mechanic work.
I started my boat the first of this year, and over rev'd the engine before pulling back on the throttle. The tachometer is no longer working. I'm watching EBayMotors.com for a new tach.
Faztbullet
The gauge I asked poster about is a single unit with mulitpule displays in it(temp/batt/fuel/oil/trim)
It can on other engines but this one has a belt driven alternator like a auto/truck....
