Evinrude 100 hp 1979 mo. 100999s. Sat forever on a 1985 Winner ZZ880 and I bought the boat for $50 Thinking, "No prob, I can do this." 5 months later....help.
The Electrical is screwed up. if anyone can help me with that (i.e. relation to battery and remote and gauges and basically everything on the boat. Does main battery power for accessories go through the remote or does it run independently from the same battery? Theres a lotta wires running from it and to it. I put a new ignition in due to previous owner had no keys, 90% certain i got the wiring right on that, I'll double check.
Anything that can help me without me ordering a $50 book I'd be much obliged. there are a few main problems...
I don't know if it runs,
I don't know what maintenance to do on it before i start it off. and...
as stated before, no electrical. So, I have some questions. I'm really rambling, so hang on.
is there a way to just hook up trim? or a way to manually lift motor? I do beleive the trim is not working properly, theres a lot of dirt and grime where the trim is located. broke the skeg taking it home. any suggestions for fixing that? skeg gaurd, etc... wow, i'm just about hopeless
The flywheel turns slowly with pressure, not the prop with the flywheel. The carburetors look clean, but haven't taken them completely off to check, kinda afraid to, would i need to replace gaskets if i did? looks like newer plugs, starter needs replaced, or that little teeth thing on top-can i just replace that? and fyi, that is about as mechanical sounding as i get.
to be quite honest, I don't know whether this is a two stroke or four stroke and what that means. I get the concept (sorta) just don't know what I got.
I just want a sense of direction for my momentum on this thing. I love fishing and my dream was for a boat and I got it. so now i gotta get it going.
I am sure I'm doubling on some other threads, if you know I am point me in the right direction please.
