runnig hot
bream master
Gday to all.After chaging impeller & thermostat & head gasket,also cleaning entire water ports,my motor still feels hot to the touch.Compression is 140psi on each pot,water stream running out of pee hole is constant stream, runs & idles great.Just to mention when i first start engine for the first 3 or so min it pumps the water fairly cold,once she warms its hot to touch,then it will go cold again & then hot its like a cold and hot scenario..........whats going on.........cheers.:cool::cool:
tashasdaddy
Re: runnig hot
that is the thermostat working, opening and closing, use an infrared thermometer, and check block temp, should be 140-160 F.
bream master
Re: runnig hot
Thanks for quick reply ,I drove down 2 mates place and borrowed his temp meter,block temp were as you mentioned 140f 143f,but still doesn;t explain why its to hot to handle.I,ve been told before that most o.m.c engines around that time liked to run a bit hotter than normal,is this true or should i b more concerned..........cheers:rolleyes:
tashasdaddy
Re: runnig hot
it would be nice to know exactly what motor you have.
bream master
Re: runnig hot
:)yeah,sorry about that,motor is a 35hp, model 35el77C
