Re: Running Volvo Penta on muffs
Thanks...I was able to download a service manual and now I understand how the two cooling systems work. Does the freshwater system (engine circuit) contain coolant or just plain water?
thanks!
Behind that pulley under the red heat exchanger housing is your circulation pump. The heat exchanger is inside the red housing. The black plastic housing with the screw on cap is your raw water strainer. The coolant resevoir is the steel cap to the left of the strainer housing.
thanks!
