woody82270
- Joined
- Feb 14, 2009
- 31
OMC 260, with osco risers. bolts rusted on. tried breaker bar, stripped head on one. any tips? Chiefalen, gimme your wisdom.
Okay tried everything suggested. NO DICE!!!! Irwin bolt extracter, pb, blow torch, cant weld nut to bolt, no room, and cant cut off heads for same reason, and yes, tried pepsi, and coke, but not rc!!!! what do you guys think of oxy/ace, and burning them off? Now, all the heads are round!!!!!!![]()
I've used the following: http://www.bt-andf.com/index.php with luck.
The other thing, after you heat the surrounding metal use an icecube on the bolt itself to try to shrink it. Must be careful, though - don't want to play with the temper too much.
