Re: scary situation
Consider yourself lucky that you could still use the boat. The beauty is aluminum props are cheap and only slightly more than getting it repaired or at least that is the case here in MN. If you don't carry a spare prop, now is a good time to get one and a spare hub, some propshaft lube and a large crescent wrench or floating prop wrench. I'm partial to the Hustler props because they are cheap.
