Re: Screwed Again Looper 120 won't run (update)
It bogs and dies when I advance the throttle. It will not go past slow idle speed without stalling. It will the restart right back up.
I have not tried disconnecting the throttle linkage, but I can observe everything moving like it should with the cable etc.
The motor will rev up fine in neutral, just not in gear under load.
Dhadley said:Does it just bog and die or does it shut off like you turned the key off? (Harker & Jtexas may be on to something)
Have you tried reving it up with just the carbs? Just advance the roller by hand. If that works then disconnect the linkage and while it's ideling advance the timer base by itself.
