Screwed Again Looper 120 won't run (fixed)
jtexas
Re: Screwed Again Looper 120 won't run (update)
Does your motor have a shift interrupt switch, or is that just on v-6's? Just a thought...
you mention swearing...have you tried begging and/or bribery? sacrifice? pennance?
alden135
No shift interupt switch.
I even offered to sleep with it, but I guess I've lost my sex appeal.
funpilot
When it doesn't start, do you have fuel in the carb bowls? You've checked the fuel lines, but they can collapse internally, and look fine externally. Might try replacing them. I think you should look at your exhaust leg, and I really like Walker's suggestion of soaking the carbs overnight and doing a complete rebuild and assuring they are squeeky clean, and blown clear. Something is robbing you of your fuel or air, or too much fuel or air at the wrong times. it has to be a fuel line, orifice or a breathing problem (exhaust / intake).
Just out of curiosity, how did you decarb if you can't get it to run?
fp
ondarvr
Did you advance the throttle by hand at the carb without the timer base being moved? I think this was asked earlier and you said you stood at the helm and could see everything move, but this is different than moving each one independent of the other while the engine is running. You may be able to identify where the problem is if it only dies when either the timing or the throttle is advanced.
alden135
fp
I decarbed right before it stopped running.
alden135
I guess I missed the point earlier about isolating the advance from the throttle. I'll try that.
Walker
You decarbed it right before the problem started. I got to go back to the recirculation system. Test all 4 valves and the inline valve. If they leak even a little bit the wrong direction replace them. Same thing happened to my 94 120 after a decarb. I tried cleaning the valves but that didn't work.
alden135
Walker,
Do you know the part #'s for those valves? I can't seem to find them.
Walker
0392988
alden135
Should I just replace them regardless as they are 16 years old now?
Walker
If they don't leak the wrong direction then they are okay.
alden135
Thanks Walker
hookedonjc
Hey Alden135 whats the latest
Just call me Blister (Always shows up after the work is done)
alden135
Walker,
You were right. I did not check the recirc valves right before. I tested them again and cleaned them and the motor is running again. I'll have to reset the timing though as I put the old PP back on when I was troubleshooting a couple weeks ago. Thanks again.d:)
alden135
Re: Screwed Again Looper 120 won't run (Walker nailed it)
Just want to make sure Walker saw this.
funpilot
I'll raise a glass to Walker! Congratulations on your perseverence, Alden.
fp
xtraham
look out fuel dock here comes alden.......
robert.barnes
can some one tell me were to buy the vro replacment that is fuel only i would rater pre mix robert-bree@sbcglobal.net thank you
Dhadley
Just an FYI -- you can soak the plastic carbs. And the throttle bodies.
alden135
Re: Screwed Again Looper 120 won't run (fixed)
Just an update to end the long saga of problems I had this summer.
1. Begining of summer all was fixed and running great thanks to all here.
2. Recirc valved clogged when I used seafoam to clean things up. Walker helped ID that problem.
3. Spent rest of summer trying to link/sync while bouncing around at the mooring and gave up in late Aug.
4. Pulled it in Sept. and found a great mech to look it over. He straightened out the linc/sync and has it running good.
Thanks as usual to all here for helping me so much.
