Sea Doo GTI 1996 type 717, hooked the water hose with it not running, what now?
SparkieBoat
My dad hooked the water hose up to it and turned it on with the motor not running. What do I need to do to safely get it running again?
FunInDuhSun
Re: Sea Doo GTI 1996 type 717, hooked the water hose with it not running, what now?
1- pull the spark plugs ASAP, ground the plug wires
2- spray penetrating oil into each cylinder
3- crank the engine- without the plugs- to expel any water thru the plug ports
4- when clear, spray in a little more oil, replace the plugs, reattach the wires, and start it
5- AFTER it's running for 20-30 seconds, turn on the water supply
6- let it achieve operating temperature to burn off any residual moisture
7- shut off the water before killing the engine!
Let us know how you do.
