lstewartff
- Joined
- Mar 6, 2013
- 53
If to much Sea Foam is put in gas will it affect the way it runs? I put a whole can (unknown ounces) in about 6 gals in my boat.
i like mixing a 50/50 seafoam and gas and spraying it into the carb.
What do you use to spray it into the carb, and do you just spray it into the air intake?
What I've done recently is mix up a half can of sea foam and about a quart of premix in a plastic Maxwell House coffee container. Drill a 5/8 hole in the top and punch some small vent holes. I stick the fuel hose in the can and run the engine in a barrel. Seems to draw a lot of carbon out.
