sea foam?
allen.wood
I have looked and looked on instructions on how to use sea foam on my 25 hp Johnson 2 stroke. I was only able to find paragraph after paragraph of complicated instructions. Could someone please give me the easy method?
Thanks!
CATransplant
Re: sea foam?
Are you talking about using it to decarbon your engine or just as an additive to your fuel for regular use?
allen.wood
Re: sea foam?
I guess d-carb, the motor runs great but it is a 1970 and I know it has tons of carbon in it and just want to clean it out some.
pcrussell50
Re: sea foam?
CAT and others,
i want to jump in here with a question of my own. both my outboards, while working well, were purchased used. as such, i've either changed, or will change, their respective impellers, and i want to do whatever else i _should_ do for them to ensure their long term health, [besides regular use].
i've been wondering about de-carboning? should i just do it for each of my outboards, since i don't know when/if it was ever done before? or do most prudent folks just use their motors till they develop "symptoms", and then decarbon? and what would those symptoms be?
-peter
CATransplant
Re: sea foam?
Heck, I don't know. I use my outboards as long as they're running well. I do regular maintenance, like impeller changes and lower unit oil changes every couple of seasons. New spark plugs go in at the start of every season, with the good old ones going into a box for spares.
De-carboning, though, I don't do unless there's a reason for it. Mostly, it's good for clearing up stuck rings, but it also does clean the combusion chamber.
Tashasdaddy has a great routine for doing it, which you can see at the link below:
http://forums.iboats.com/showthread.php?t=281046&highlight=decarbon
It can't do any harm, and might improve performance slightly on a good-running outboard, but not by much.
iwombat
Re: sea foam?
I decarb every 50 hours or yearly whichever comes first.
pcrussell50
Re: sea foam?
ok i'm convinced. where is the iboats-approved place to buy seafoam? i'd like to support iboats with this if possible.
-peter
Mas
Re: sea foam?
Any auto parts store will carry the stuff!
MAS
tashasdaddy
Re: sea foam?
i like to support iboats also, but i buy mine at Advance Auto Parts. some walmarts have it.
tashasdaddy
Re: sea foam?
also adding seafoam to the fuel, per directions on the can, is good for keeping clean carbs clean. it will do nothing for dirty carbs, until you clean and rebuild them.
