Re: sea king 5 h/p what year
<I don't think the water pump is working on this sea king. Is the three ,i'll call them hash marks half way down from the power head to the prop where its to weep water out or am i wrong becouse its not.>
Yes---the 3 chevron shaped openings are the exhaust relief/tell-tales on that Gale-built motor. If the waterpump rotor were working you should be getting a VERY noticeable amount of spray from them. If the large o-ring seal around the exhaust leg between the pivot bushings is kaput you may also get water out of the top bushing that will run into the boat.
The rotor is located behind the plate that is behind the prop. It must fit closely around the cam but loosely in the housing to function as designed. Contact Brian Wilcox for a replacement. (810) 794 - 7685
