Seal a cooler / livewell
Off-Peak
Hi Gang.... to get my livewell to fit under the leaning post I had to trim a corner half an inch and now a bit of the foam core is exposed... What ideas are out there to seal the open area to prevent UV and water damadge? (cooler is white)
Thank you!!
jonesg
Re: Seal a cooler / livewell
I'd try to find a peice of angle alum or a plastic strip that could be glued with 5200, using sealant by itself just won't look good and will probably trap dirt. Maybe split a peice of pvc pipe, or look at angle trim at home depot, a lot of that stuff is made from plastic now.
You might have to cut a bit more from the cooler to allow for the trim peice.
The nice thing about owning a ratty old boat is it doesn't matter.
Beat it to fit and paint it to match.
Off-Peak
LOL... yeah, this boat is getting to that point... I have been fixing junk for years and wouldn't know how to act with a new boat!!!
I like the PVC idea and its not that bad, just think I need to keep dirt, water, & UV out of the foam.
