Sealer on transom bracket bolts
a70eliminator
What is the prefered method for sealing the transom bracket-motor mount to the transom.
There's no gasket on anything. On my evinrude the upper bolts have to come completely out to raise it a hole, the lowers can just be loostened but still breaks the seal if there ever was one.
accidently posted in the wrong section oops.
a70eliminator
Re: Sealer on transom bracket bolts
Thanks, that is what I ended up using but it wipes off when I push the bolts through the bracket, ok so I just use it liberally and clean off the eccess, I guess that's all I can do, although I'll have to hold off using any at all until I test with the new height, then I'll have to make sure it's all dry in there before I seal it for good.
Thought maybe there was a trick, I'm tempted to open the holes bigger plug with a fiberglass dowel and redrill so no exposed wook to soak up water.
tashasdaddy
4200 is almost permanet, 5200 you will have problems getting things apart, if you do get them apart.
