cprince
Thread starter- Joined
- May 22, 2008
- 148
I do not have any "Holes" in the hull, but it does appear to be leaking pretty good around the drain plug and perhaps from some seams. I have some left over Poly NoWax Resin...
Taking in account that I will prep the seams with an aluminum brush and clean it properly.
Is Poly effective in sealing seams on aluminum?
I am not using much HP at this point on the boat, and I am not looking for any structural reinforcement. I have heard the contention about aluminum corroding under poly... but I would bet that it was from moisture penetration after de-lam. But I suppose that is the crux of my question; would it de laminate from aluminum? (Again... I will/would be applying on a brushed and clean surface)
Thank you for any and all input.
