Re: sealing gas lines on I/O gas tank fill?
Hose to bib connections are compression seals and thus do not require a sealer. If you see some type of a material on the existing connection it's a hose lubricate used during assembly.
As for the one or two clamp? Federal law says two
FEDERAL LAW
183.564 - Fuel tank fill system
(b) Each hose in the tank fill system must be secured to a pipe, spud, or hose fitting by:
(1) A swaged sleeve;
(2) A sleeve and threaded insert; or
(3)
Two adjacent metallic hose clamps that do not depend solely on the spring tension of the clamps for compressive force.
Fuel tank fill system hose connections shall be made to a pipe (smooth pipe is acceptable), a spud or a hose fitting. The hose connections may be made by one of the following means:
(a) Swaged Sleeve: This type of connection is usually made by the supplier of a hose assembly, since special machinery or apparatus is necessary to perform the swaging operation. The attachment to the fuel system is usually made by means of a threaded hose fitting.
(b) Sleeve and Threaded Insert: This type of connection usually can be made by an installer using normal shop tools. Usually the sleeve is placed on the outside of the hose and the threaded insert screwed into the inside of the hose and sleeve. There are connections in which the sleeve is installed on the hose after the insert is installed. The attachment to the fuel system is usually made by means of a threaded hose fitting.
(c)
Two Adjacent Metallic Hose Clamps That Do Not Depend Solely On The Spring Tension Of The Clamps For Compressive Force: For a fuel tank fill line, 2 hose clamps are usually slipped on each end of the hose in a loosened condition, the hose installed and the hose clamps tightened. The attachment to the fuel system is usually made by means of a beaded, flared or serrated spud, pipe or hose fitting. Hose clamps are to be installed side by side, not on top of each other.
Two clamps are required for mechanical strength and to resist any tendency for the hose to twist.NOTES:
1.Spring wire and other type clamps that depend on the spring tension properties of the clamp material are prohibited from use on fuel line installations on boats.
2.Wire type hose clamps are not acceptable.
http://www.uscgboating.org/regulations/boatbuilder_s_handbook/fuel_standards_partg.aspx]
