What does the rubber plug that you push in the impeller to the back of the housing do? Is it needed?
J jhilton Seaman Joined Nov 23, 2008 Messages 66 Jun 22, 2010 #1 What does the rubber plug that you push in the impeller to the back of the housing do? Is it needed?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,472 Jun 22, 2010 #2 Re: seawater pump impeller Ayuh,... On What,..??
J jhilton Seaman Joined Nov 23, 2008 Messages 66 Jun 22, 2010 #3 Re: seawater pump impeller On a seawater pump 1994
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,472 Jun 22, 2010 #4 Re: seawater pump impeller jhilton said: On a seawater pump 1994 Click to expand... Well,... It acts as a Bearing in the seawater pumps on 94 Nuclear Subs....
H HT32BSX115 Supreme Mariner Joined Dec 8, 2005 Messages 10,083 Jun 22, 2010 #5 Re: seawater pump impeller jhilton said: On a seawater pump 1994 Click to expand... Lessee.......94 sea water pump........I'm trying to guess.... You're just going to have to be a little more specific. Could you narrow it down a little... please ? Dana, Scott Atwater, Lauson, OMC, Volvo Penta, Mercuruiser (Alpha or Bravo)l Well I guess Scott Atwater, Lauson, are out of the picture...they weren't around in 1994.....
J jhilton Seaman Joined Nov 23, 2008 Messages 66 Jun 22, 2010 #6 Re: seawater pump impeller mercruiser seawater pump 7.4 liter, crownline 250, 1994, carburetor, one piece body on pump and it is mounted on the starbord side.
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,511 Jun 22, 2010 #7 Re: seawater pump impeller page 6A-5 this link, what part number? http://www.boatfix.com/merc/Techbk/97/97hga6.pdf
J jhilton Seaman Joined Nov 23, 2008 Messages 66 Jun 22, 2010 #8 Re: seawater pump impeller It was not on there, i only have an old manual. Thanks. What is the quad ring?
J jhilton Seaman Joined Nov 23, 2008 Messages 66 Jun 23, 2010 #9 Re: seawater pump impeller Seems that everybody likes to reply with not enough info until they have it all. The quad ring,(after 4hours on the phone) is just an o-ring. never mind!
Philster Captain Joined Sep 15, 2009 Messages 3,344 Jun 24, 2010 #10 Re: seawater pump impeller Eventually they tire of making an effort when the person in need of help won't make the effort. Understandable.
